Post more details like the format of the file (delimiters, organization, etc), how you are reading the file, any errors, etc, and most importantly, the facts that lead you to the "does not seem to recognize" conclusion.
As a string I can get "3.06E-010" to convert to 3.06E-10 (double) quite nicely. Are you sure LabVIEW is not just displaying it as zero because the number is so small?
There are no errors reading in the file but the output on the graph shows just a linear increase which is wrong. The format is just an ascii file with points structured as: 1.00, 3.06E-10 and so on. Any help?
Given the format of your data, you dont want to use a Waveform graph, you want an XY graph. You want an XY graph because you have X data and Y data. You could use and Waveform Graph, but you would throw half of your data away.
I suspect the reason you are seeing a linear increase of your data is because you are only looking at the X values, which, oddly enough, are increasing linearly.
Take a look at the attached VI and see if it does what you expect.
