Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
3
4
I am trying to read in an ascii file and output it onto a waveform graph...
Re: I am trying to read in an ascii file and output it onto a waveform graph...
fudawala
Member
06-11-2008
02:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
After doing the Read From Spreadsheet, do a Delete From Array and remove column 5. You can see the extra column yourself if you open the Read From Spreadsheet and run it by itself. Can you clarify this. Thank You.
0
Kudos
Message
31
of 31
(352 Views)
Reply
2
3
4
All Forum Topics
Previous Topic
Next Topic
