I am trying to use a SC-2024-RTD DAQ board to do 3 things (monitor two sensors (input) and control a small motor (output)) simultaneously. I have not been successful using labview for output. I can't even get it to show a voltage at the output pins.
I have it configured for voltage modulation, channel 0, and I am testing Ix0+ and Ix0-. To run it, I am right-clicking on the function and clicking "test". What's wrong?
thanks, Alex Millie
amillie@stanford.edu
(2,727 Views)
Ix0(+/-) are make the excitation current. You can see this in figure 4-1 in the user manual. You can see the output voltage from the MIO card by looking at the voltage from terminal 23 to terminal 20 (channel 0) and terminal 23 to terminal 21 (channel 1). You can see this pinout on page 3-5 of the SC-2042-RTD user manual.
(2,727 Views)
