Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I am trying to use the vi server feature and "call by reference" to manipulate controls on a vi running on another pc but when I use the "call by reference node" it has no terminals to match the controls of this vi??
johncahill
Member
09-14-2004
07:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
could anybody help? thanks
0
Kudos
Message
1
of 2
(2,294 Views)
Reply
Re: I am trying to use the vi server feature and "call by reference" to manipulate controls on a vi running on another pc but when I use the "call by reference node" it has no terminals to match the controls of this vi??
Chienwei
Member
09-14-2004
09:03 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
A couple of things to check:
1. did you wire the "type specifier VI Refnum" in "Open VI Reference.vi"?
2. If you want to change values of any controls when the VI is running, you should use an invoke node.
Hope this helps,
Dan
0
Kudos
Message
2
of 2
(2,294 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
