I am trying to write a heartbeat program which takes the current time and writes
I am trying to write a VI that gets the current time and writes it to an XML file in this format.  YYYY-MM-DDThh:mm:ss[.s][Z|(+|-)hh:mm]
I cant seem to get the operators on the format date/time string vi to work for concatenating the "-" between the year and month
Anybody know how to do this one?
(2,834 Views)
You should not need to use special operaors for the format date/time string, the format should simply be"%Y-%m-%d"
(2,824 Views)
thanks
(2,811 Views)
