I am unable to edit 'tables.vi' (part of report generation)
I wish to create a table in a report, using different column widths. I've saved 'Append text table to report.vi", "tables.vi" and "set table column width.vi" under different names, without update callers.
When i make any change (placing any function), the report data property turns black, and error are given. I've noticed that NIReports.report item of the data clusters returned form "Generate report data to modify.vi", does not have any properties when connecting it to a propery node.
(2,490 Views)
Can you post a stripped down version of your code that reproduces this behavior? I am not sure if something on the VI turns black or the report turns black. If you get an error message what is it? What version of LabVIEW are you using?
I found a link to a document that you may find useful.
Tables in Standard Reports are Limited in Width, Regardless of Margin Settings
(2,490 Views)
Thanks for responding my questing.
It seems that the something in the labview installed at work is corrupt. Because at home I do not have this problem.
I'm using Labview version 6.0.1b3. At work I'm using windows NT, here I'm using windows 2000. Might this have anything to do with it?
I'll try reinstalling Labview at work to see if it solves the problem.
Thanks again,
Arnold
(2,490 Views)
