I am using HP 4263ALCR meter, and I am trying
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viwhen I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.vi
Message 1 of 12
(3,564 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viIf you were to right click on the error code and select "Explain Error", you'd get the following:
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
Are you sure that you specified the correct gpib address. You can check this in Measurement and Automation Explorer (MAX). Under Devices and Interfaces, you should see your gpib card listed. Right click on this and select "Scan for Instruments". Your instrument should be found. If you highlight the instrument and select properties, you should see something like "GPIB::3::INSTR". Type this value into the VISA Resource Name control or just click on the select arrow of the control to see the list of all available resources and select the one
you want.
Message 2 of 12
(3,564 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viWhen you try Dennis' suggestions, let us know what you find out. Although I don't have the instrument, I've downloaded the driver and can try to help you out with it if you haven't already resolved the issue.
J.R. Allen
Message 3 of 12
(3,391 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viThanks Dennis,
I tried checking all the GPIB cards listed but no instrument is found, I followed the prompts to add a new hardware system, adding the hardware I am working with (AT MIO 16E 10) but the problem remains.
Message 4 of 12
(3,564 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viSounds like you have a problem with MAX. You say "all the GPIB cards listed". You have multiple GPIB cards in your system? What type? What OS are you using and what version of MAX/GPIB?
Message 5 of 12
(3,564 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viNo, I was expecting to find a list but I didn't. This PC has got Measurement and automation explorer version 1.0.1, when I open it and click on Devices and interfaces appears GPIB interfaces not found, and an advise to run NI488.2 troubleshooting wizard, that's what I did but no hardware is added after following the prompts.
Message 6 of 12
(3,564 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viWhat happens when you run the Getting Started Wizard? For some cards and OS's, you have to specify the card type, interupts, etc. and then the program verifies software and hardware installation. What type of GPIB board are you using and what OS?
Message 7 of 12
(3,564 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viThe system verifies the software, but no hardware is detected; I follow the prompts from troubleshooting wizard, to add the AT MIO 16E 10, but the problem remains.
My OS is Windows 98 and the GPIB board says E2071/82341, it's got a type 2 HP-IB cable of 2.1m.
Message 8 of 12
(3,564 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viThe AT MIO 16E is a data acquisition board and not a GPIB board so now I'm really confused as to what your're attempting to do. I don't know what E2071/82341 means either. Do you really have a GPIB board that you're trying to install? All boards from NI should say so on the board and on the metal face plate. If this E2071 is not a NI board but is a GPIB board, then installing NI-GPIB is a waste of time. You have to install whatever driver software that came with it and use something other than MAX to configure it.
Message 9 of 12
(3,564 Views)
to use the driver to make impedance measurements. when I go to getting started and try to run it, an error messagge appears, VISA Open inError -1073807343 occurred at VISA Open in Error HP4263A Initialize.vi->HP4263A Getting Started.vi->HP4263A VI Tree.viYes , you are right, sorry I didn’t know but the GPIB card is from Hewlett Packard, I’ve got the AT-MIO-16E and the PC-DIO 24 from national instruments, I already ran the getting started HP4263A.VI but when I try to run the HP4263A example I.VI an error appears:
Error -1073807346 occurred at VISA Write in HP4263A Config Averaging.vi->HP4263A Example I.vi.
Possible reasons:
VISA: (Hex 0xBFFF000E) The given session or object reference is invalid.
Message 10 of 12
(3,564 Views)
