I am using LABview 5.0 and I am having difficulty with running EXCEL 2000 and my macros after I build an application.
Excel opens and runs the macros correctly in my development programme, but when I build an application and try to run it, Excel opens but does not put the data into the cells or run the macros. Excel opens and runs the macros correctly in my development programme, but when I build an application and try to run it, Excel opens but does not put the data into the cells or run the macros.
The error message is 'Object is not registered in set cell value.vi code-2147220997
I stress that it all works OK until the application is built. Set cell value.vi was downloaded from this site. I am using Windows 98.
Any help would be appreciated.
(2,698 Views)
Be sure you have your Excel activex controls properly registered in your system, there are lots of activex registerers in the web. If this does not work, look at set cell value vi and check for invalid refnums. If even this fails, i'd try reinstalling app builder, but be sure you install it before any LV update (for example 5.0.1f1) unless you want problems like i had with Excel built examples. You can also send an example, and see if i can fix it, but i don't have excel 2000 (only 97) so i don't know if i can do anything else.
Hope this helps
(2,698 Views)
Thanks for your help, when I finally re-installed the application builder, the problem was corrected.
Many Thanks
(2,698 Views)
