Hallo Jasmine,
How are you measuring the pH? Are you connected to a meter over a serial
(or other data) connection or have you connected the pH electrode directly
to your hardware (I`m not familiar with the PCI-20428W)?
Depending on the type of pH-electrode, you may experience high level of
interference, which of course Enrique`s mail already dealt with.
If you try to attach a glass pH-electrode directly to a card, you need to
watch the input impedence of the card (or use an amplifier) as a glass
pH-electrode can have an impedance of over 400 Megaohms...
Shane
Jasmine schrieb in Nachricht
<506500000008000000B01E0000-986697009000@quiq.com>...
>I am using Labview 5.0 to write a program to measure the pH value for
>my experiment, the obtained values should be constant.
Why the data
>from AIRead is fluctuating instead of constant values?
>Is this caused by the hardware (Intelligent Instrumentation:
>PCI-20428W), the software (LabView 5.0) or the noise?
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
