I am using application builter and it give me an error when I use the HTML vi´s
Error 1003 Ocurred at c:\rafa\internal.llb\tables.vi
possible reason
this VI is not executable
Whe I erase the part of HTML file my builder works fine.
help me I have to delive the programa tomorrow and I live in colombia.
(2,324 Views)
The problem is that something in the "tables.vi" function is broken. Fix that problem and the build should work.
When you open tables.vi in the development system, does it show a broken arrow? If not, does the VI call any DLLs? Sometimes the app builder misses DLLs that it needs to include.
If you still are getting the error, post the tables.vi in 6.0 format and I'll look at it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,324 Views)
