I am using the NI application note "Calling IVI-COM drivers from LabVIEW" I created an Automation Open and an Invoke Node, after wiring
the 2, the AN asked to right click the Invoke Node(this is step9) and choose initialize. However there is no intialize option on the pop up menu. Anything am I doing wrong? I am using Labview6 and I did add the "enableCustomInterface=True" in the INI-fileThank you for your help.
T Tall
(2,508 Views)
the 2, the AN asked to right click the Invoke Node(this is step9) and choose initialize. However there is no intialize option on the pop up menu. Anything am I doing wrong? I am using Labview6 and I did add the "enableCustomInterface=True" in the INI-fileT Tall,
What's the number of the application note "Calling IVI-COM drivers from LabVIEW"? I'm unable to find what you're looking at.
--Bankim
(2,508 Views)
