I can change the formula in a formula node programmatically !
Just to let you guys now,
You can change the formula in a formula node programmatically.
I was looking into this because the "Eval formula node" is way to limited to do any real calculations.
Just have a look a this VI.
We use VI server to give the name of the VI in which you want the formula node to be changed.
Then VI server makes a link to the first formula node it finds in this Vi, an changes the formula
with the string you attached.
Really cool isn't it ?
cu,
Thomas.
(5,229 Views)
Just be forewarned that the thread may be removed, because NI does not support scripting and they will not want you getting people to use these features on their site.
___________________
Try to take over the world!
(5,219 Views)
I'm sorry i won't do it again ... 🙂
thanks, guybrush.
(5,209 Views)
A remark : I also found out that you can't build a working executable from your VI if you use this trick...
(5,167 Views)
That was expected. There is no way an executable can modify a VI.
LabVIEW, C'est LabVIEW
(5,134 Views)
