I can not add NI 9981 module to cRio 9053
I want to work with the NI9881 CanOpen module and my cRio 9053 but I can not add the module to my chassis. I am working with Labview SP1 32bits, so installed FPGA module 21, Real-Time module 21, NI CompactRIO 21 ,NI-Industrial Communications for CANopen 21.5 and NI DAqMx 21.8. But I can not add the module in cRio 9053; however I do can add in cRIO 903X.
It is missing something? or there are any compatibility issue?
(1,510 Views)
The 9881 is not a FPGA C module if I'm not mistaken and needs to be added as a Scan Interface resource to the new 904x and 905x chassis.
Rolf Kalbermatter  My Blog
(1,489 Views)
I can not add it either in the SCAN and FPGA mode. I would think that is a problem with NI Industrial Communication CAN Open but I don't know why I can add it in other cRio chassis.
(1,475 Views)
