I can read and write to my device in MAX, but serial read and write VI's don't work
I am trying to communicate to a Stanford Research Systems SR 245 digital analog convertor via LabVIEW.  In MAX I can write commands to the device and read from the device, and everything is working fine.  In LabVIEW the device is never written to; the "bytes at port" is always zero.
I am connecting to the device via a DB9 to DB25 cable.  I don't fully understand how this works; is there any way this could be causing the problem or does the fact that the commands work in MAX imply that it is simply a problem with my VI?
I have an indicator on the "return count" terminal of the "serial write" VI which says that there have been 2 bytes transferred (or other value), but as I said, immediately following this in the data flow, the port contains zero bytes.  If I exit the program and open MAX, the instrument does not exhibit the state I would expect had the write-command actually registered (although I'm not positive that I can conclude anything from that).
Thanks very much for any suggestions.
(2,548 Views)
Something is wrong with your VI. Perhaps you are not sending a termination character. Do you have '\' Code Display turned on?
(2,529 Views)
Also, unless I'm mistaken, "bytes at port" refers to incoming data
(2,525 Views)
n00b mistake.  Thank you!  And yeah I was wrong about bytes at port as well.
(2,508 Views)
