I can start my vi but executable asking for sub-vi when it starts
My vi starts right up but when I created an executable it ask for sub vi's when it starts. What's the progblem?
Message 1 of 11
(3,498 Views)
We are not mind readers. What subVI is it asking for? Is this a VI that ships with LabVIEW? Is this a VI that you wrote? Is this a VI that you're calling dynamically? If so, did you include it in the "dynamically called VIs" list? What LabVIEW version are you using? What's in your project?
Message 2 of 11
(3,487 Views)
Is it an executable you built from your VI?
Did you make an installer so that all dependencies (including necessary subVIs) are installed?
Cory K
Message 3 of 11
(3,483 Views)
Maybe you are using VI's which are called dynamically? If so, you have to include them in the "Always Included" section of Source Files when making the Build Spec.
Also, path constants can get you into trouble with EXE's, like Default Directory path and Current VI's Path.
Richard
Message 4 of 11
(3,467 Views)
I don't think they are called dynamically..
Message 5 of 11
(3,462 Views)
How do you make installer? Doesn't it ha[[en automaticcaly when you create an executable? I'm using 2009.
Message 6 of 11
(3,461 Views)
Don't you know? Didn't you write the code?
No. An application is separate from an installer. The installer ... installs the application. The process of creating an application and an installer are fully documented in the LabVIEW Help. Please read that first and then come back if you have specific questions.
Message 7 of 11
(3,452 Views)
I didn't write that portion...
Message 8 of 11
(3,450 Views)
No, just because it makes an executable does not mean you have a complete installer.
An installer has:
- the executable
- the run-time enginer
- dependencies
If you do not create an installer, you will only have one of the three necessary components
Cory K
Message 9 of 11
(3,443 Views)
Well, we're still not mind readers, and you still haven't given us any more useful information, such as what VI(s) it's looking for. Unless you can look at the code yourself and determine whether the VIs are being called dynamically then post the code.
Message 10 of 11
(3,436 Views)
