I can't creat R-series(USB-7855R) devices in my project.
I'm trying to use USB-7855R. My system information is below
OS : window 10
Labview 2018
Labview 2018 FPGA module
and I have a USB-7855R.
I installed
1.labview
2. FPGA module
3. and then the lasted version of NI R series Multifunction RIO devices driver.
After install all of those by the order,
I can see my 7855R in the NI-MAX.
So I  tried to creat a new project and add new target device but I can't creat R-series devices for a target.
Does anyone have same problem?
(2,733 Views)
Are you using LabVIEW 64-bit?  Judging by the icons, you are.  It appears that your device is not supposed in 64-bit LabVIEW.  You should consider using LabVIEW 32-bit instead.
For more information:
FPGA Targets Supported by LabVIEW 2018 FPGA Module (64-Bit)
LabVIEW 2018 FPGA Module Readme
(2,692 Views)
Hi there, I am experiencing the same issue with LV2020 (x86). The device shows up in NI/MAX but it is impossible to add it as a device to my project. Did you find a way to fix it?
(1,445 Views)
