I can't find the CAN example folder in Example Finder
Hi everyone,
I just finished installing the NI-CAN driver for the USB-8473 High speed CAN interface but I can't seem to find the examples in Example Finder that comes with the driver.
I checked to see if the driver is working on the USB 8473 and it is working just fine ( I can see it in MAX).
The specs : LabView 64bit 2018
                    NI-CAN driver 18.5.0
I appreciate your help,
Thanks in advance, Achref92
(2,829 Views)
According to this KB NI-CAN is only compatible with LabVIEW 32bit.
EDIT:
The readme of CAN18.5 confirms this, it is not compatible with LabVIEW 64bit
Regards, Jens
Kudos are welcome...
(2,809 Views)
Thank you so much, I installed the 32bit version and it works !!
Best Regards, Achref
(2,789 Views)
