I can't get data to show up in graph
Hello - I'm having trouble getting my data to show up in a graph. I read voltages or temperatures from an input channel and show the value on the front panel, send the data to a file, and I'd like it to show the data in a graph to see how the data has changed over time.
My block diagram is attached. Can anyone tell me why I am not seeing the data on the graph? If I use auotscales, the scales will change based on the data but I will not see the data. The only times I have seen data, the time axis doesn't move and I just see a dot or vertical line.
Any help would be appreciated!
Thanks!
(2,711 Views)
It is better to keep all postings regarding the same topic in one thread. Just reply to the last posting in your earlier thread.
Your attachment did not get attached. Do not Preview your post after attaching a file or the attachment will be removed.
Lynn
(2,706 Views)
