I can't get the voltage measured by voltmeter.
As Gerd says you did not change to RSE. Start by actually reading the help this time.
Message 11 of 19
(1,318 Views)
I changed in Creat Channel.
Also, I tried DAQ assistant. The voltage it gets is weried. And I don't know how to save the data.
Message 12 of 19
(1,316 Views)
You did not change a thing with the create channel. Since you refuse to read the help to solve the problem yourself, why should anyone try to help you?
Message 13 of 19
(1,311 Views)
Sorry. I put a wrong pic last time. I edited the pic in the last massage. I add a RSE.
Message 14 of 19
(1,307 Views)
So then everything is working then. Good.
Message 15 of 19
(1,304 Views)
No. It still says two terminals are different type.
Message 16 of 19
(1,304 Views)
Accepted by topic author Jshen6
Hi Jshen,
so then you did not read my message?
Message 17 of 19
(1,298 Views)
Message 18 of 19
(1,294 Views)
That is a shipping example and you broke it by trying to connect the physical channel control to an unused terminal. Disconnect the wire to the unused terminal.
Message 19 of 19
(1,279 Views)
