I can't installing an AT-MIO-64E-3 on a Compaq Deskpro EP/SB Series running Win NT SP 6.
NI DAQ 6.81 can't see this PnP device, and in the list of new devices is it also not listet, and so I couldn't install it manually..
The BIOS found this ISA PnP card correctly, but under WIN NT is no way.
Thanks ahead, Axel Kob
(2,561 Views)
Windows NT is not a PnP OS, and unfortunately installing ISA PnP boards on this OS can be tricky. For some troubleshooting suggestions, I would suggest that you visit:
http://www.ni.com/support/daq/winnt/pnp/pnt.htm
This troubleshooting wizard will give you some helpful hints on what to check for if NT is not detecting your board.
Hope this helps! Otherwise, I would recommend visiting ni.com/ask for technical support.
Erin
(2,561 Views)
