Try shutting down LabVIEW completely, and then running the VISA Interactive Control.
Maybe you still have a port open somewhere. LabVIEW often only releases the ports after exiting LabVIEW, not just after closing the VI which had opened the port.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
