I can't scroll a Dialog Ring.
The ring values scroll but you can't see it scrolling up or down. When you select any item, it selects the value as if the values have scrolled and not the value that you click on. Can some one help me on this? Thanks!
(2,533 Views)
I can�t reproduce the behavior you�re describing � you need to give a more precise description on what you are trying to do. Are you referring to a Text Ring control? Do you mean using the arrows when you say �scrolling�? What version of LabVIEW are you using?
Please provide us with an example that shows the behavior, thanks.
Philip C.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,533 Views)
