I can talk with Keithley2400 by NI-MAX, but cannot control it by labview
I use Labview2017 to control the Keithley 2400, and it is okay to communicate with Kei2400 by MAX VISA test panel, shown in fig. However, I cannot control it with my labview program, as shown in the 2nd fig.
Then, I tried to use the examples to control Kei2400, but it doesn't work, because I even can not choose the GPIB VISA number, as shown in fig 3. Can anyone tell me how can I solve this problem?
Tons of thanks!
Sincerely,
Yen-Po
(2,959 Views)
This isn't a permenant solution but try adding some 'magic waits' of about 100ms between commands.  I've had problems with Keithley GPIB controllers not being able to handle solid strings of commands off a LabVIEW VI in the past. This was the solution I had to go with, just control the command send rate so that it wouldn't overwelm the Keithley
Best of luck.
(2,951 Views)
Try manually typing in the VISA resource name GPIB0::23::INSTR and see if you can find it.
Also don’t use the comma as a decimal separator. Most instrument syntaxes needs to use the period “.” Even though you regional settings maybe otherwise.
(2,939 Views)
Did you install device drivers with LV 2017? It seems very odd that nothing shows up in the drop down...
(2,901 Views)
This is a duplicate post - https://forums.ni.com/t5/LabVIEW/problem-with-connection-between-GPIB-and-Labview-LV2016-and/td-p/37...
You are using a Agilent/Keysight USB-GPIB you need to enable the NI-VISA Passport for TULIP. Follow the advice from RSTLVU in the other thread and see if that works.
Craig
(2,884 Views)
