I cannot build installer because NI-RIO was not found.
When I try to rebuild my installer it gives me an error that says "The following product(s) are not found on the system or have been upgraded: NI-RIO 12.1". It is true that I upgraded NI-RIO 12.1 to NI-RIO 13.0.  But I do not know how to tell the installer where NI-RIO 13.0 is located.
I'm guessing the problem is that the installer is on LV12 and I also have LV13 installed on the same computer.
The image below shows that I do have NI-RIO 13.0 installed.
What is the best solution to this problem?
(2,514 Views)
Either install NI-RIO 12 or build this in LV13.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(2,489 Views)
I ended up changing it to LV13. I don't think you can just install NI-RIO 12.1. I think you have to uninstall NI-RIO 13 then install 12.1. And when you are done you can reinstall 13.
(2,485 Views)
