I cannot communicate between Labview 2019 and HID Compliant devices
I am carrying out a project that I need to communicate a UPS with Labview. This UPS has a proprietary driver and has a USB port. I have already tried to use the Driver Wizard to create a VISA Driver based on the Vendor ID and Product ID, when I replace the original driver with the VISA driver the UPS stops communicating with the Proprietary Software.
I found a file that says that HID Compliant devices are special cases and cannot be overwritten by a VISA driver. This article guides the use of the direct call to HID.dll, through the function "Call Library Function Node", however I was unable to make such a call by the example of Labview.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MD4SAM&l=pt-BR
Has anyone had a similar problem and could send me an example of a VI using this feature and working with HID.dll? or suggest some other solution to the problem? PS: I can communicate between the UPS and other programs that normally capture data from USB, so the driver is correctly installed and the equipment is working.
Message 1 of 1
(1,742 Views)
