I'm trying to build the tkdpo4K.llb into a dll for use with LabWindows CVI, Teststand and C#
Error generated:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at Invoke Node in ABAPI Dist Build App from LLB.vi->ABAPI Build Shared Lib With Old Proto2.vi->DBEP_Invoke_Build_Engine.vi->DBUIP_Build_Invoke.vi->DBUIP_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488: Non-existent board.
Method Name: Build:Application
