I cannot read and write information using the Modbus API library and the serial port becomes unusable when the program is run.
Im also using the same drive. Having doubt on this drive. If I changed any parameter of the ASD A2 drive through LabVIEW once means. will the set value remains same even after power off ? does it keep in its memory? If it is not means what should I do for that ? Please support.
Thanks in advance.
Message 31 of 37
(1,953 Views)
Hi. I'm also receiving the same error code 56 while communicating delta ASD A2 with LabVIEW. how you have solved. please reply..
Thanks in advance
Message 32 of 37
(1,939 Views)
Hi there. Im using Delta ASD A2 drive. Im trying communicate the drive with LabVIEW using Modbus. I'm receiving "Error 56 occurred at RTU Data Unit.lvclass:Read ADU Packet.vi:5030001" whenever I tried to read or write. Can anyone please tell me what to do for solving this issue.......
Thanks in advance
Message 33 of 37
(1,947 Views)
Thanks in advance
The reason for this error may be that an address I want to write does not accept the value you have written. If you write a value to a parameter that it cannot accept, you will get this error.
Message 34 of 37
(1,911 Views)
Thanks for your reply. Right now I have made established the communication.the error is because of wiring mistake. Now it is rectified. But now I can able to write through LabVIEW. Can't able to read from the drive. No error coming but the registers values are not initialised while reading. In modpoll, I can able to read. Could you please support.
Thanks in advance
Message 35 of 37
(1,891 Views)
Did you solve your problem?
If you still can't solve your problem. Can you repeat what the problem is?
Message 36 of 37
(1,852 Views)
Thanks for your reply. I have solved the issue. The problem is with the NI modbus library with machine. So I have used another library tool called plasmionique modbus master toolkit from VIPM. Through that read & write operation has been done.
Message 37 of 37
(1,849 Views)
