I cannot run NI Example Finder
i learned this tip from another site, it might help solving your problem.
check your virus scanner setting to excluding the example finder exe or best of all, the entire National Instrument folder, it solved my problem.
if you also experience slowness in shutting down labview (at the same time the cpu usage jumps up), then exclude labview.exe from your virus scanner as well.
-Joe
Message 11 of 12
(750 Views)
I solved my problem by disabling hyperthreading in my computer. It locks and make slower most of my labview features.
Thank you
Message 12 of 12
(747 Views)
