I cannot see the NI-DAQmx icon in measurement window in Labview 2013 (student Edition)
Hi All:
I have installed NI-DAQmx and Labview 2013 (Student Edition). I have connected an NI USB-6008 DAQ and tested it using NI-DAQmx and it is working properly.
Now I tried to do logging of data from this device using the installed Labview software but as I  open a new project and go to Block Diagram screen and display the measurement menu I cannot see the NI-DAQmx icon in the measurement window (Menu) within Labview 2013 (student Edition).
Any suggestion?
I am attaching two screen shots.
Please help.
(2,702 Views)
Accepted by topic author Mus90
In which order did you install the software packages?
You should install LabVIEW first, followed by DeviceDrivers!
(2,698 Views)
Thanks for your prompt reply.
I will re install DAQmx again to respect the installation order.
Regards
(2,691 Views)
Thanks alot. It is working now.
I really appreciated your support.
Regards
(2,660 Views)
