I cannot show a control in the front panel
I have to debug a program from a ex-collegue of me.
He somehow has hiden controls which I cannot view in the front panel.
I tried the option "show control" and "hide control" but that does not work.
How can I solve this problem.
(2,548 Views)
Hi darkxceed,
What are the controls(Boolean, graph...) that you are mentioning? I'm not sure, but check whether they are made transparent. Right click, select properties and check in the appearance tab. since you have already tried through hide and show control but still try to check through "visible" property node and see(just in case....)
______________________________________________
Kudos are welcome
(2,543 Views)
Well it was not transparent.
I deleted all controls and noticed that when I deleted a TAB the control also disapeared!
Thus then I made the Tab control visible and it the also showed the control.
Thanks for reply tho!
(2,536 Views)
