I cant find DAQ solution Wizard button
I am using CB-68LP with CPI1409. I am unable to find any information on your website about PCI1409. Also I am using Labview 7.1 and I cant find DAQ solution wizard button.
Regards
Muhammad
(2,832 Views)
At the top of the page is a search field. Just enter 1409 into there. I just did that and got 503 results. The 1409 is an image acquisition device.
I'm not sure what you are looking for with a DAQ solution wizard button or what that has to do with the 1409. If you have a DAQ board and have installed DAQmx, on the Measurement I/O>DAQmx palette, you will have the DAQ Assistant
(2,823 Views)
