I cant list the contents of my *llb help please
I have this error message "An error occurred while listing the contents of xxxx.llb"
I think the file is corrupted can I recover the vi's inside?
(3,914 Views)
NI might be able to. You can try contacting them by going to NI Support. A corrupt llb when you don't have a current backup can be a major problem. That is why they should never be used in development to save your VIs. The intent of an llb was to give the use the ability to create VIs with longer names than the old dos 8.3 format. The only reason to use an llb now is to make distribution of a project simpler. Good luck.
(3,903 Views)
Finally I have contacted with NI support and they recovered my damaged llb. I'll put my vi's in a safer place next time. bye.
(3,876 Views)
