I cant watch my VIs published on web using Netscape
I cant watch my VIs published on web when using Netscape 4.78.I have Labview 6.1 installed.Do I need to install RTE?
(2,485 Views)
Hi
If you are using the Netscape on the same PC where LV is installed, than it should work! If you want clients who don't have LV installed to be able to view and control a front panel remotely using a Web browser, they must install the LV RTE.
Bye
Luca
(2,485 Views)
