I couldn’t install PCIe 6321 with Simulink 2010a
I have NI DAQ card (PCIe 6321). I tested it using the NI software but I couldn’t find the DAQ number in SIMULINK MATLAB 2010a to install it.  Please how can I solve this problem?
Best Regards,
Maher
(3,206 Views)
Hello Maher,
Could you explain your application in a little more detail? How are you selecting the DAQ device in it? Could you provide screen shots of what you are seeing? Are you using Simulation Interface Toolkit (SIT) in LabVIEW to talk with this device?
Also for the PCIe-6321, is this being recongized on the computer as well as in MAX?
Jim St
RF Product Support Engineer
(3,194 Views)
Hello Jim St,
I'm using MATLAB SIMULINK to implement voltage control. I measure the voltage (Analog input) then implement my controller using Simulink MATLAB (Digital PI controller) and finally send the control signal (Analog output) to the process. I use the real time windows target toolbox in the SIMULINK to build analog input and the analog output. Unfortunately, I could find my DAC number in the list of National Instruments which is defined by the SIUMLINK MATLAB so I could not interface the MATLAB with the NI card. My card number is PCIe 6321 and I’m using MATLAB 2010a.
Best Regards,
Maher
(3,178 Views)
This is not LabVIEW question. Have you asked Mathworks?
(3,174 Views)
