I'd like to control/read INCA with LabView.
Hi Amp12,
I am trying to setup the communication between LabVIEW and INCA which are installed in the same computer. I was also getting error when selecting ActiveX class in INCA_COM_Test.vi.
Could you tell me which object I should choose from MR1 library to set up the communication?  I tried several but they will cause error(not exectuable).
You mentioned testing different libraries, but it seems to me that I can only select certain object from one of these libraries.
Thannks
Jian
Message 31 of 34
(2,624 Views)
JianZ,  You will need to direct your question to Hannes.Cape, as I was unsuccessful in implimenting the code used in INCA_COM_TEST.vi.
Message 32 of 34
(2,587 Views)
I have modified VIs provided by @dryan0929 and I am able to update ECU Parameter,  I have tested attached VI to change the values of the parameters in the ECU.
It is working fine for Intermediate delay of more than 150 ms between read and write operation.
User ManualUser ManualWrite/Update Register -Block DiagramWrite/Update Register -Block DiagramWrite/Update Register -Front PanelWrite/Update Register -Front Panel
CLD
Message 33 of 34
(1,841 Views)
Tapan,
I have used your TCP_vi to make communication INCA with labview,however the ICNA 'ASAM MCD 3MC ' page have not received the command form labview,is there anything wrong withe the setup of labview? and is there new version of ASAP3 vi driver ?
Message 34 of 34
(1,453 Views)
