I'dd like to use LabView to attach to a CNC FTP server and download and unplad information to it. I'm using 6.i
I am trying to attach to a FTP server on a CNC machine. I have been looking for code in 6.i that I can use with out buying the internet tool kit.
(3,166 Views)
Nick,
With 6i, your best bet is to use DataSocket. This is covered in other DevExchange forum threads and on the NI Web site (KnowledgeBase, DevZone examples), but I know it's tough to find just the nugget you need.
Here's what I'd suggest as reference:
1. LabVIEW shipping example called "DS Reader.vi". Find it in your version by doing Search Examples >> Communication >> DataSocket >> DataSocket Reader
2. This KnowledgeBase entry on the URL format to use when connecting up to a resource on an FTP site (covers logging in): http://digital.ni.com/public.nsf/websearch/bae38f5848be7c098625672400640233?OpenDocument
3. This one on how to explicitly get an unformatted text file using DataSocket:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/f3
cc5f7e60a75cb2862567e700696abf?OpenDocument
Hope it helps,
John Lum
(3,166 Views)
Thanks John:
I had found the items that you refered to, however, could not get them to work. I'm new at LabView, so am probably doing something wrong. Any more ideas?
Nick
(3,166 Views)
Nick,
I'll bet you're having trouble because you're trying to retrieve unformatted text (i.e. not a .wav or .tdt or some other common format). In this case, I think you want to use the [text] argument on the end of the URL, as outlined in one of the KB docs.
I've attached an example that I can run here without error; it retrieves one binary (zipfile) and one textfile from the ni.com FTP site. Try it and examine what I did.
Best of luck,
John Lum
(3,166 Views)
I am not sure what you are need to collect from the FTP server, however there is a supplier of LabVIEW to CNC machine tools out there at a reasonable price. You might check out the "machine link" product at http://www.controlinksystems.com/
I would be happy to discuss this further with you or your team.
Sincerely,
Preston Johnson
Business Development Manager, Industrial Applications
512-683-5444
preston.johnson@ni.com
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,166 Views)
