I designed a VI,but I don't konw whether it is correct? Please help me cheak it !
My VI and schematic diagram are in the below attachment.
Message 1 of 9
(4,305 Views)
I don't have the Modulation addon available, but those who have, will miss some initial values of yours. Select all controls and indicators on the front panel (press ctrl-A), then go to Edit > Make current values default and upload the saved VI again. Cheers,
Message 2 of 9
(4,264 Views)
It looks alright but maybe you want to put a while loop around it so you can modify the control values and see what happens to the output. I also dont have the AM/FM modules either though.
Message 3 of 9
(4,232 Views)
It executes. You might want to consider setting default values for all your controls. For example the VI error if you have 0 samples. Also would recommend connecting up error flows.
Message 4 of 9
(4,223 Views)
Thank you!I have already uploaded my VI,please help me cheak it again!
Message 5 of 9
(4,199 Views)
Message 6 of 9
(4,198 Views)
Message 7 of 9
(4,197 Views)
It still executes without error.
Message 8 of 9
(4,080 Views)
It looks reasonable.
Does it do what it's supposed to, or do you have any specific problems with it?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 9
(4,061 Views)
