I did not find "Switch Execution Target" from Labview 6i?
The attached VI which I got from NI website does not have the section Operate>>Switch Execution Target>>RT Engine. Where can I find this feature in Labview 6i. Thanks
(2,825 Views)
DN,
These VIs are designed for use with LabVIEW Real-Time. You must have the Real-Time Module installed in order to see the Operate>>Switch Execution Target menu item in LabVIEW.
Chad H.
Applications Engineering
http://www.ni.com/ask
(2,825 Views)
