I do not have a boolean input on watchdog open.vi
How can i get a false constant on my watchdog open.vi because it doesnt have a boolean input
(3,033 Views)
Please provide us the information to which library/tool the "watchdog open.vi" belongs.
Your question is currently like: Why is there a fish missing in the pool? One has to ask: What pool?
Norbert
Norbert
Expert: Geometry
(3,032 Views)
it is in the WPI Robotics library>>utilities>>watchdog
(3,027 Views)
Watchdog open.vi indeed does not have a boolean input.  Who told you there was?  What functionality were you expecting from it?
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(2,993 Views)
there was one before the update i saw it in the 10 minute motor control to put a false constant on the watchdog open.vi
(2,978 Views)
We developed a semi-custom set of controls for our FIRST controllers.  Since you are not using FIRST software, your vi's may differ slightly.  The boolean input on that control is simply an enable/disable, which would be equivalent to putting your Watchdog Open in a case structure.
If you are using FIRST software and hardware, then this needs to be moved to the FIRST forums.
Rob K
(2,970 Views)
