I don't get output to an indicator in a recursive VI
    I'm trying to create a simple text parser with LabView.  So far, I only want the parser to recognize three commands:
*loop n - indicates the start of a loop of commands to execute n times
*endloop - end of section of commands to loop
*pausetime n - pause the reading/output of commands for n milliseconds
I use a "Scan String for Tokens" to break the text in a text control by line breaks.
I use a case structure to recognize those commands with a default case that passes any other text to a text indicator.
I figured the easiest approach to dealing with the loops would be to make the VI recursive.
When I don't have a *loop/*endloop pair in my text control, all the other text gets sent to the text indicator correctly, and the *pausetime appears to pause the reading correctly.
When I have a *loop/*endloop pair in in my text control, the loop index is parsed correctly, the VI is called recursively, the "offset past token" is RETURNED as the point beyond *endloop, but I don't see any of the commands that lie between the *loop/*endloop pair ouput to the text indicator.
Can someone suggest what I might be doing wrong?
Jason Mazzotta
Message Edited by JackOTrades on 06-08-2010 02:10 PM
(2,953 Views)
Nativie recursion was added in LabVIEW 2009. You are using 8.5 so you definitely have a serious penalty here.
 You code is so full of outrageous code constructs that is makes little sense to try to understand it all.
Examples:
  • Convert INF to I32 to wire to N of a FOR loop. What's the idea???
  • Obscure bitwise operations: String size NOT(OR "1") for a case structure. What???
What would be a typical input string?
(2,928 Views)
I am a bit new to LabView programming and I'm trying to get the program to work at all.  So, I haven't had a chance to consider the best options for some of what I've done but ...
... to create an infinite loop.  I could use a while loop, but I wanted to use the same FOR loop for finite and infinite looping
That is simply check to see if *loop has a parameter.  I could use a comparison operator, and probably will, but that's what I found first off and it works.
A B C
*loop 3
D E
*endloop
(2,920 Views)
There is no "infinite" for integers.
 Just wire the string directly to the case selector terminal. One case is "empty string" and the other the "default".
(2,916 Views)
