I encountered a problem with my data storage!!!
Hello all,
The generated file from Labview is created in tdms format and can actually be opened in Excel with the TDMS Importer. However, something happened with the attached file. Do you have a solution to make this file readable again?
(1,015 Views)
Hi Alex,
So what happened to your file?
It does not comply to expected TDMS file formatting anymore…
(Did you open the TDMS file using a simple (Windows) editor and saved it?)
(988 Views)
That's exactly what I don't know.
The logging was started and stopped normally as always. Probably it was not closed properly!? The logging mode has been running like this for about 5 years, it has never happened until now.
(976 Views)
Unfortunately not, the file was saved only in TDMS format...
(972 Views)
(Have you opened and saved the TDMS file with a simple (Windows) editor?)
Sorry I misunderstood. The file was not opened and saved with an editor
(965 Views)
