I forget a part of my password for diagramme sheet
how can i find my password for the diagramme sheet (i remember only a part it)
(2,745 Views)
Old question - old answer: look at http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000131D0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0 etc. Even NI is not willing (not able ?) to help in this cases because this kind of protection mechanism should not become senseless ...
(2,745 Views)
Passwords can be tested programmatically. Open a reference to the VI in question and wire it to an invoke node with the Set Lock state method. Now you can write a code that will try different passwords. Write a password generator that generates all possible combinations. If you know the password must be between 3-5 letters etc...restrict the generator accordingly. If you ever use real words you can let the generator use a dictionary.
I think there was such a password finder on http://www.citeng.com/ at one time but could not find it again (could remember wrong), perhaps someone else has is in their user library still though.
The number of possible combinations per second is a bit limited so if the password is much more than 4 characters and you need to run
a brute force attack it could be too tough.
(2,745 Views)
Check out Brian's LabVIEW Page and look in the download section for a brute force password cracking VI.
(2,745 Views)
