I get Error 1316 when uninstalling 7.1.1 Run-time Engine
I've been had trouble installing NI Development Suite.  To get around this, I tried to start with a clean slate by removing all previous version of NI software.  Everything uninstalled okay except 7.1.1 Run-time engine.  I get an Error 1316 followed by Error 1603.
I'd like to avoid doing a "system restore" to the days before LabView 7.1.1.  Too many other programs and settings would get affected.
Additional info:  I'm running Vista and I've turned off my Kaspersky antivirus program.
Any ideas on gettng past this error?
(2,840 Views)
these may help
If you are running vista, you can try the registry cleaner here: http://digital.ni.com/public.nsf/allkb/D3A4261454C01583862573D0006BA3C2
Although your issue is slightly different, this may help: http://forums.ni.com/ni/board/message?board.id=170&message.id=293117&requireLogin=False
Here is a link to the Microsoft Registry cleaner: http://support.microsoft.com/kb/290301
Paul
(2,832 Views)
