I have 1 GPIB board with 3 instruments:can I acquire data from them simultaneously?
I'm going to connect 3 instruments (two Infratek Wattmeters and an Agilent multimeter) to my GPIB board and I want to collect data from them simultaneously.I'm working with Labview on Windows NT or 2000. How can I do that?
(2,667 Views)
You should be able to relatively simultaneously. You can use either hardware or software triggers. If the instruments have a trigger input, then you can program them to take a measurement when the external trigger event occurs. If you don't have a method to generate that trigger event, then a software trigger might work. GPIB supports the Group Execute Trigger and this function can be found on the Instrument I/O>GPIB palette. I say relatively simultaneous because there's always going to be some delay between the receipt of a trigger and the measurment actually being taken. You'll have to determine what is actually meant be simultaneous and whether the instrument's specs are good enough.
(2,667 Views)
thank you Dennis for your prompt suggestion. I'll try and then I'll tell you what happened. Thank you again!
Carmen
(2,667 Views)
