I have 10 different sub vi's, which are added to llb. Eac
h sub vi will have default information in the table. sub vi named like 'application - 123.vi'. Using the number '123' on main vi I have to construct vi name and open that sub vi and read the values of table to an array. does any answer my question. Thanks.I have 10 different sub vi's, which are added to llb. Each sub vi will have default information in the table. sub vi named like 'application - 123.vi'. Using the number '123' on main vi I have to construct vi name and open that sub vi and read the values of table to an array. does any answer my question. Thanks.
(2,696 Views)
h sub vi will have default information in the table. sub vi named like 'application - 123.vi'. Using the number '123' on main vi I have to construct vi name and open that sub vi and read the values of table to an array. does any answer my question. Thanks.Here is an example. Run the main VI and you can choose which subvi you want to call (App-1.vi or App-2.vi).
I hope it will help you.
(2,696 Views)
