I have X-310 and want to design FM reciever using labview FPGA,any relevent example or document
I want to design FM reciever on X-310 hardware using Labview but i want to use FPGA-side processing instead of host-side processing to achieve larger bandwidth.Currently i am only able to achieve 10 MHz with host-side processing,i want to go to atleast 20MHz.
(920 Views)
Duplicate post here: https://forums.ni.com/t5/LabVIEW/X-310-target-using-LVFPGA-for-fpga-side-processing/m-p/4215740#M122...
Your post is too open ended to get help on the forums.  Forums are there to help with more specific questions.  Have you tried anything that has not worked?  Do you know where to begin?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(890 Views)
