I have a 2D array of 50 columns wide, I want to split it in 2 so that I can calculate the average of one half.
Is there a quicker way, except from;
Read spreadsheet file, Index array for each column I want (25 of), build these back into an array and out put to an indicator.
My program is included.
(2,980 Views)
Yes, there is.  Using Array subset, you can output any block of that original 50 column array.  I changed what you posted and attached what you need to split it into 2 arrays.  Read more in the help for Array Subset.
(2,972 Views)
Oops, sorry I forgot to mention I am using LV7.1, can you re-save for v7 for me, thanks.
(2,969 Views)
Hmm, I thought I did.  Sorry about that.
(2,967 Views)
Thanks, I would never have figured that out!
(2,963 Views)
No problem, that's what the forum is here for.  Glad I could help.
(2,954 Views)
