Showing results forĀ
Search instead forĀ
Did you mean:Ā
I have a data type issue regarding calling. net assemblies
@Freddy. wrote:
So the only feasible solution currently may be to write another DLL to pass the structure……
That is your conclusion! 😁
I have on occasion gone the path of passing the entire structure into individual parameters through the Call Library Node (and add conditional compile to do the other thing for 64-bit) but yes it is painful and if there is anything else about the API that gets difficult to impossible to handle through the Call Library Node (callback pointers for instance) I always resolve to an additional intermediate shared library.
Rolf Kalbermatter  My Blog
Message 31 of 37
(1,352 Views)
My understanding is to split all parameters into one cluster? (I'm sorry, most of the time I use translation, so I don't quite understand some of the meaning.)
Message 32 of 37
(1,336 Views)
I split the elements in the cluster and imported them into the library function... Obviously, this is not correct. Labview still crashes, so how should I modify the cluster for this library function to function properly?
Message 33 of 37
(1,331 Views)
Accepted by topic author Freddy.
That is not what I was explaining to be necessary for structures being passed by value.
This is a start of what needs to be done. Sorry for not doing all the nitty gritty work. šŸ˜€
ā€ƒ
Message 34 of 37
(1,307 Views)
Could either of these toolkits be an alternative option?
https://www.ni.com/en-us/support/downloads/tools-network/download.robotics-toolkit-for-yaskawa-motom...
https://www.vipm.io/package/imaginglab_gmbh_lib_yaskawa_robotics_library/
-AK2DM
"It’s the questions that drive us.ā€
Message 35 of 37
(1,297 Views)
Good morning, I immediately understood your code snippet! I have completed the remaining work. Well done, labview finally stopped crashing and I got the desired return code!
Message 36 of 37
(1,286 Views)
This is not a good choice, this third-party library is too expensive. I have already developed the encryption dog for the secondary development module of the robotic arm (the price is half of the robotic arm)
Message 37 of 37
(1,273 Views)
