06-07-2006 05:02 PM
06-07-2006 05:46 PM
I am curious... I also have codewarrior installed, but I've never had a problem with Flexlm.
Which version of LV are you using?
06-07-2006 07:46 PM
06-08-2006 12:58 PM
06-16-2006 09:47 AM
Sorry for the slow reply. I thought Codewarrior support was going to fix this but I'm still having problems. They did give me a temporary license and I can now use Codewarrior and LabVIEW but if I try to use my "real" license for Codewarrior, it doesn't work.
Attached are the screenshots of the registry...
Thanks for your help.
-Dan White
06-16-2006 04:13 PM
06-19-2006 12:35 PM
FWIW I've had extended and unresolved problems with FlexLM used by other products (SolidWorks, Fluent, Gambit). I removed these products from my laptop, but later my new installation of NI's MAX wouldn't open unless the laptop was plugged into our network. On a hunch, eliminating the user environment variable LM_LICENSE_FILE = ####@AAAAAAA in Control Panel > System > Advanced fixed the problem. [this web site looks like it's formatting that variable value as a web site, underlined, but it's intended as plain text.]
This doesn't fix the OP request to make both programs work together, but maybe it's worthwhile as a diagnostic, or to others in my situation?
06-19-2006 12:49 PM
