I have a labview 7 vi and i have labview 6.1
I have a labview 7 vi that get data from excel specified field. I have only labview 6.1 : could someone translate or "save as" these vi in labview 6.1 format ?
Thanks in advance.
(3,074 Views)
vi's converted to version 6.1
(3,073 Views)
thanks very much, but i have a error when running it :
status: red cross
error code : -2147352565
Index incorrect.
in Excel_Get_Data_Specified_Field.vi
and the error code is not listed.
(3,073 Views)
It does not appear to me that this is a conversion error. It is more of what the vi is trying to do than anything else
The max count (i32 representation) is 2147 483 648
and you a reporting an error or value of 2147 352 565
It may be related to the max count or some data inside the file
(3,073 Views)
The first time I ran your VI without error. I ran the VI again with a bad sheet name and got the exact same error code.
It seems that your workbook does not contain a sheet with the name specified. There is no provision for trapping this condition. If the sheet is not found, the Search 1D Array function will return -1, and an index of 0 is invalid.
Michael
Certified LabVIEW Developer
www.abcdefirm.com
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(3,073 Views)
Now the vi is working, thanks
but i can't choose only one cell to appear on my front pannel: there has to be at least 2. i have to look at it
thanks everybody
(3,073 Views)
I'd like to know if you have the reciprocal function, i.e how to convert a range or just an Excel column name (A, B, etc.) to an array index and so on?
Thank you in advance.
Bim
(3,025 Views)
